Message 1 of 5
L:inking my TV to my computer
have broadband and You view all supplied by BT. How do I set up the link between my computer and my Tv (which is a smart TV) so that I can get BBC I player and Amazon prime etc??
4 REPLIES 4
Message 2 of 5
Re: L:inking my TV to my computer
if smart tv does it have wireless connection or just ethernet?
Message 3 of 5
It has wireless connection
Message 4 of 5
Then just go to the TVs and network section and look for available networks and when you see yours then try and connect. You will need the wireless password and then connect
no difference to basically to connecting mobile to your network
Recognised Expert
Message 5 of 5
If possible the best, most reliable solution is to run an ethernet cable from the router (Homehub) to a network switch by the TV. Then connect the TV and the Youview box and any other "smart" AV box (eg DVD player) to the network switch with short ethernet patch cables.
How you hide the long run of cable depends on your particular home but I have mine tucked under the edge of the carpet running all round the dining room (where the router is which doubles as my study) and the living room.  General advice is that the cable can be up to 100M long so more than plenty for the typical size of home.
