davidfowler
Newbie
Message 1 of 3
Loss of Freeview Channels
Has anyone else lost the Freeview Channels in Oxfordshire? I live in Banbury and the advisor I've just spoken with tells me that the transmitter is down. However he gave me Cow Hill and Brightstone. The first seems to be in the Highlands and the second on the Isle of Wight!
Looking at a Freeview map it DOES show a transmitter near Oxford has work going on.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Loss of Freeview Channels
Hi davidfowler,
Welcome and thanks for posting. Are you up and running again? Let us know how you're getting on.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
davidfowler
Newbie
Message 3 of 3
The engineer has visited but says the fault is with the aerial so I'll get an aerial fitter in to double check. It's very strange however that it was only when I reset the box did the channels disappear. Re-tuning the channels doesn't work.
