A body missing HD subscription channels except sports after the update?
No @Tezz I've got all of mine back. Are they missing altogether from the EPG ( 370 to 393)?
Seems just certain ones, such as Gold HD Sci-fi HD, not sure how many, they are showing on TV guide, but not set up.
Select Gold HD and follow the prompt to set it up. That's what I did, I assume it's something to do with validating the HD subscription.
@Andy005wrote:Select Gold HD and follow the prompt to set it up. That's what I did, I assume it's something to do with validating the HD subscription.
When you pressed ok, what message did you get at first?
To be honest @Tezz I can't remember, but I know I've done it before. What are you getting?
Got these 2 screens, got the now tv after pressing ok on the first one.
Sorry pictures ended upside down.
I assume that you do have UK Gold as part of your subscription, make sure that you're on 392 and not 358, which is the new Now TV offering. I nearly made that mistake.
Yes have the top tv package. On channel 358.
