Message 1 of 6
Lost all terrestrial channels...again
Today, for no reason, for the second time, all terrestrial/Freeview channels via the arial were lost and a Freeview channel planner for record failed because of it.
I did a retune, all came back and all ok afterwards. This is the second time in a month, last time was away so lost a lot of planned recordings.
Signal quality is very very good on testing, so what's going on?
Before last one I gave the box "a rest". Powered it off for a while, to restart hoping to avoid any problems when away....
The UHD box is all up to date and was a replacement about a year ago.
Anyone else have this?
5 REPLIES 5
Message 2 of 6
Re: Lost all terrestrial channels...again
What is the signal strength like, it should be no more than 95% otherwise you are likely to be get overloading which will cause loss of channels and failed recordings. It also needs to be at least 60%.?
Check it on all channels to make sure.
Recognised Expert
Message 3 of 6
Yes I keep losing some but not all of the terrestrial channels on my box, not sure if it's because of a fault or changes to the channel plan.
Message 4 of 6
Sig strength on a lot of channels is 99% and quality is 100%.
So if that's too high what do I do? Why lose all channels though?
Message 5 of 6
99% should be fine as its usually 100% that gives the issue.
Sounds more like a faulty box.
Do you lose all channels on the TV at the same time, as that would indicate an aerial issue?
Message 6 of 6
So far all yes. Came back and lots of failed recordings.
Retune gets them all back though.
