EVOGT
Message 1 of 3
Lost channels
Hi guys,
It appears that my BT Youview box has lost loads of the frreview/aerial channels, but I still have internet channels. I have reset the box and re-tuned it but still loads missing. For example chaneels 1-17 are missing.
Andy ideas?
2 REPLIES 2
rarmitage124
Recognised Expert
Message 2 of 3
Re: Lost channels
Do you get the channels when you plug the arial straight into the tv?
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
EVOGT
Message 3 of 3
Re: Lost channels
Hi,
Sorry been away all week. Yes if I put the aerial into the TV I have all the free view channels etc. If I retune the bt box it might find 144 channels, then it might find only 89 so summit is wrong. Then five mins later it says weak or no signal then goes off.
