bellini
Newbie
Message 1 of 3
Lost recordings from old style Bt box to You view box #2
if I keep my old Vision box which has lots of recordings on it, can I unplug my new YouView box, plug in the old one and continue to watch recorded programmes?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Lost recordings from old style Bt box to You view box #2
Hi @bellini and welcome.
If the recordings are stored on the box hard drive then you should be able to watch them. Can you try reconnecting the box and let us know how you get on?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Message 3 of 3
If you recorded any extra channels, you may encounter difficulty, as a licence check has to be made via the servers, to make sure you are entiltled to view the content.
