luckstar69
Message 11 of 12
Re: Lots of missing channels with just a black screen SD, HD and 4K channels
Hi,
I believe that BT Wholesale were contacted and asked to look into this. The lady on the phone said a home visit would be the last resort but it may be fixed by then.
TimCurtis
Guru
Message 12 of 12
@luckstar69
As you've had problems with the Youview box since the beginning I'd be inclined to think that it might be the issue and a replacement unit is required.
I had problems with the UHD box and eventually after 2 swaps went back to the standard , more reliable box. Not an option for you with a UHD package though.
