Message 11 of 23
Re: Missing a substantial amount of Freeview channels
Remember, this is only a customer to customer help forum, and I am just a customer.
I have suggested that you have your distribution amplifier checked. If you are just using a splitter, then you are likely to get poor results, and interference between the different YouView boxes, as a splitter does not give any isolation between outputs.
This is most likely the cause of your problems.
This is described on my web page.
You are unlikely to fix the problem any other way, so the choice is yours.
NorthEasterner
Message 12 of 23
So the splitter which I have used for years will be causing interference now?
The splitter which is a 4 way with power pass has been given us good signal from the loft aerial.
I ask again, what is a Distribution Amplifier and Sensitivity on the YV box?
gomezz
Recognised Expert
Message 13 of 23
Could be if its power supply capacitors have gone kapput which is a common fault with much modern electrickery.
NorthEasterner
Message 14 of 23
But the splitter provides signal to all other TV's in the house.
The fault seems to be limited to just the particular YouView box in that particular room.
I find it bizzare to be honest when all other TV's work inc other YV boxes and work in the particular room.
Will try and get a 6dB attenuator and see if that helps.
Message 15 of 23
Does your splitter look like this Aerial distribution amplifier
If it is, then it may have gone faulty, or its being affected by 4G signals.
Read the thread that I referenced.
https://community.bt.com/t5/YouView-Boxes/HD-Signal-Strength-and-Quality-Issue/td-p/1776303
I doubt that an attenuator will help, but you can try it. The only real answer is to get your aerial and distribution system checked properly.
It may mean that the splitter (amplifier) may need to be changed, if its 4G interference, or that other box has a fault on it.
I assume you have the BT YouView multiroom option, so you can watch the extra channels on two boxes?
You need professional advice on your aerial distribution system.
NorthEasterner
Message 16 of 23
This is it Labgear 4 WAY SPLITTER WITH POWERPASS ALL PORTS
I highly doubt my aerial, cabling or distribution is at fault if my other Youview box works fine in the bedroom with the exception of the new box.
Yet the new box works okay in the living room.
All aerial points link back to the same aerial to the same splitter as well.
Not going to get much help bringing in a profesional to have a look when theres nothing wrong with the incoming signal but the actual youview box.
Strangely if I press down the aerial cable and hold it down the picture clears itself and gets a signal (at the bedroom outlet) but this is impossible to keep like that when not pressing down on it.
I have tried different fly leads and no change.
Yes I subscribe to Extra Box service for £5 extra per month.
No offence, but seem to be repeating myself here - advising there is nothing wrong with the incoming aerial signal, splitter or cabling.
Happy christmas, NE
Message 17 of 23
That is just a passive splitter, with no amplification. Its only any good if you are in a strong signal aerial.
You are likely to get different signal levels at each outlet, depending on the length of the cable.
Anyway, you can see if any other forum members have suggestions.
gomezz
Recognised Expert
Message 18 of 23
Try swapping the feeds at the distribution device end and see if the problem moves to or stays with the Youview box in question.
Message 19 of 23
That splitter you are using, has quite a signal loss, and its different for each outlet.
Insertion Loss: 6.8dB 7.0dB 7.8dB 8.0dB
Your issue is that you are simply losing too much signal, and the normal variation between YouView boxes, means that the one you are having problems with, simply needs more signal.
Get a proper distribution amplifier which has no loss, and gives the same output on every connection.
The one that I illustrated, works just fine.
Its the SLx 27820HSG Four Output Aerial Distribution Amplifier costs about £15.
Andy005
Message 20 of 23
Happy christmas, NE
If you can press down on the cable at the outlet socket and the signal improves, that would suggest to me that there is a problem with the outlet socket such as a cracked joint.
As for your other Youview box working in that room, that is a bit odd, is it exactly the same spec. as the other?
