peter1uk
Message 1 of 4
Missing channels on BT TV app.
When does the app usually update its channel listings as I currently have Forces tv missing on the app, but it is available on my box. I am also missing some of the shopping channels although I don't mind these missing. Anybody else having this issue.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Missing channels on BT TV app.
Hi @peter1uk Check Channels available on the BT TV App. It says that you won't be able to watch the Freeview channels on the App.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Distinguished Guru
Distinguished Guru
Message 3 of 4
I interpreted @peter1uk issue as  Forces TV ch 96 not being listed in the BT TV guide  that the BT. TV app accesses when it commenced broadcasting. It  is now listed so the app can be use to set recordings for that channel on the Youview box.
peter1uk
Message 4 of 4
Yes, my issue was that it was not listed on the guide, but it has now appeared.
