Message 1 of 8
Moving home and my fastest speeds are lower than what I have now
Where I am currently I get up to 76MB but at my new house the most is 65MB
with s lowest amount I could get of 40MB
Think this will be an issue with UHD content?
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: Moving home and my fastest speeds are lower than what I have now
Hi @NickH161,
What was the speed estimate for your line at your new address? Can you enter your telephone number in https://www.dslchecker.bt.com/
Please make sure to remove the number before posting back the results.
The minimum requirement for UHD is 44 Mbps but this refers to the connection speed and not the throughput speed of your connection.
PaddyB
Message 3 of 8
Interesting.
I was told categorically last week that the speed estimate must have a minimum of 49mbps for UHD to be supplied. Actual sync speed & throughput is apparently irrelevant as far as BT sales are concerned.
Message 4 of 8
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC ADSL 2+ Up to 3.5 -- 2 to 6 Available
ADSL Max Up to 2.5 -- 1.5 to 5 Available
WBC Fixed Rate 1 -- -- Available
Other Offerings Availability Date
ADSL Multicast -- -- -- Available
Postcode only checks will not ret
Message 5 of 8
When I check what speeds I can get it does say as much as 65MB
Message 6 of 8
Is it a totally new house, or is there an exiting owner with a phone line?
Message 7 of 8
Somebody was living there yes. I imagine there would be a phone line but when I moved into my flat there was no phone line.
Message 8 of 8
Its just that if there was somone with a phone number, you could use that number in the availability checker.
