walkerx
Recognised Expert
Message 51 of 193
Re: Multicast Settings for 3rd Party Routers may not work
some routers don't work well when using as an access point - took a while to get my asus working properly as an ap
setup your HH3 as normal
setup your airport for an ip address below HH3 (ie 192.168.1.250/255.255.255.0/192.168.1.250 and DNS point to HH3)
disable DHCP on airport
connect to HH3 and devices should work fine
both my youview boxes are connected to the HH4 and everything else to my ASUS RT-N66U and all working fine - can also then configure both devices from PC
cactusbob
Message 52 of 193
Done all that, still doesn't work. Mind you I've noticed my HH3b doesn't appear to be on the latest firmware, and doesn't appear to want to upgrade either.
aseymour
Message 53 of 193
Just curious - what do the settings need to be - I oddly can't seem to find any particular setting for my TP-Link router, under LAN I get the following;
Enabled
IGMP Proxy:Enabled
IGMP(Internet Group Management Protocol) works for IPTV multicast stream.           The device supports both IGMP proxy with enabled/disabled option and IGMP snooping.
That appears to be the only options I have, or at least I haven't found anywhere else I can do any kind of IGMP configuration. My on-demand content works fine but no IPTV channels (might not be enabled in this area yet?).
foxkilla
Message 54 of 193
have you tried the latest 1393 firmware for the asus yet?
Paul
walkerx
Recognised Expert
Message 55 of 193
that has no fixed features for the IPTV stuff included in the previous update.
ASUS are litterally dragging their feet on getting this resolved, have already told them it is extremely bad support
jonstatt
Message 56 of 193
@TimCurtis wrote:
I've had a response from Billion saying that they can't see that whether it's ethernet or wireless connection should actually matter.
I'll add that the response wasn't a 100% guarantee, but I'd feel fairly confident about that.
Thanks Tim, Just wish Billion would bring out an ac wifi router.
apshep
Message 57 of 193
I have just tried the sport channels and get the IP6023 error. I'm using a HH4 via wifi (TPLink TLWR702N) with no issues on the BT app. All the sport channels display a black screen with the same error.
All catch up services work fine via the same wifi connection.
I've rebooted the box with no change.
Any suggestions? I guess its the same IGMP problem on the TPLiink but not sure where to start.
Colin_London
Recognised Expert
Message 58 of 193
You are trying to use multicast via WiFi?! Smiley Surprised
Well I think that's your problem. WiFi might be OK for unicast streaming on-demand content where there is a buffer, but the requirements for multicast (with very little buffering) are much more demanding.
For consistency of service (delay & jitter)
WiFi < Powerline < Powerline AV < Direct Cable
And BT don't support anything below a direct cable.
cactusbob
Message 59 of 193
I can confirm that the IPTV channels work fine with Infinity and a TP-Link TL-WDR4900 N900 router. No fiddling required
Red_Snow
Message 60 of 193
Hey Zarf2007
Could you perhaps please provide an update as to how your Billion 7800DXL is performing? Are you using Youview and able to see all BT Sport/ESPN and Test Channel through this router?
If yes, would you recommend it and were there any special configurations that had to be applied?
Thank you
>mark
