Gavhugill
Message 11 of 12
Re: Multicast enabled at exchange but can't get bt tv entertainment package
FTTC Range A (Clean) 20.7 14.5 2.5 0.8 -- Available
FTTC Range B (Impacted) 17.7 7.9 2 0.8 -- Available
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
Hi above is the output from the bt wholesale site. It seems to suggest 14.5 as a minimum on the fttc range a (clean).
My bill States unlimited bt infinity 1.
My neighbour confirmed today he gets the entertainment package and kids channels.
Is there anyone I should seek to talk to that won't just give me the 'computer says no'?
Gavin
Moderator-Retired
Message 12 of 12
Hi Gavhugill,
Thanks for your post.
I am sorry that you are being told we can't provide you with Multicast channels. I will get this checked out for you.
Can you send me in your details using the "Contact The Mods" link found in my profile and I will be in touch.
Cheers,
OlgaC
Community ModeratorOlga
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
