David7270
Newbie
Message 1 of 3
Multiroom
I have two YouView boxes and would like to get an extra box subscription.  Not being able to see any option for this on the website. I don't need to  buy mini connectors (£20) or have an engineer install (£49).  As I already have an wired ethernet connection where the 2nd box is going I don't need either.
Just to add, although both boxes are BT YouView+ boxes, BT only provided one to me, the other I picked up elsewhere.
2 REPLIES 2
Message 2 of 3
Re: Multiroom
Welcome to this user forum.
See http://bt.custhelp.com/app/answers/detail/a_id/48891/~/can-i-watch-bt-tv-in-more-than-one-room%3F
You may have to order a non-recordable box, but you do not have to use it, as your other box can be used instead.
There may be an option just to add the extra subscription without the box.
-Richie-
Expert
Message 3 of 3
Re: Multiroom
You can order a 2nd box subscription without needing to add extra hardware, you'd most likely have to call to have it done, speak with either the Value or Loyalty team to add it.
Ring 0800 800 150, they close at 8pm tonight though, try tomorrow between 9-6pm or weekdays is 8-9pm
