QoQ
Message 1 of 3
My BT TV box won't allow me to record
Pressing the record button on my BT TV box ultra HD type won't set any recordings now.
I have 51% space left, the remote works fine for everything else, I've switched the box off and on and the same.
I went to the BT app on my iPhone and tried to schedule a recording that way and that's not working either?
It's connected via ethernet direct to my box, which is working as I can watch BT sport etc
What's going on? Anyone else with the same?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: My BT TV box won't allow me to record
@QoQ Can you try a factory reset of the Youview box to see if that helps?  You can choose to keep your recordings if you reset it using the buttons on the box
QoQ
Message 3 of 3
Just tried a factory reset, keep recording and still no good and now reset all my recording....great....
