varkanoid
Message 1 of 4
My Ultra HD box gets stuck on "Nearly Ready" since H26.40.0 with SMART on
Since the update to 26.40.0 and when SMART is enabled my Ultra HD box gets stuck on the YouView "Nearly Ready" screen. I have left it for over an hour and it just sits there. The only way I can get it to turn on is to switch it off using the switch at the back several times. Anyone else having this problem ?
I have a normal HD Box which had the update 26.40.0 ages ago and this is set to SMART and it wakes up fine.
3 REPLIES 3
4KMarty
Message 2 of 4
Re: My Ultra HD box gets stuck on "Nearly Ready" since H26.40.0 with SMART on
No. Mine's working fine.
rarmitage124
Recognised Expert
Message 3 of 4
Have you tried a maintenance mode reset:
https://community.youview.com/youview/topics/top_tip_soft_reset_reboot_power_cycling_maintenance_mod...
Hopefully that helps, if not post back
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
varkanoid
Message 4 of 4
I did the mainenance mode reset and it seems to have done the trick.
