CMC01
Message 1 of 7
My bt remote in our upstairs bedroom switches on the bt box and TV downstairs
Recently, my upstairs bt remote switches the upstairs TV and box but also our dowstair lounge one. I tried recoding the remote but this didn't work.
6 REPLIES 6
gomezz
Distinguished Expert
Message 2 of 7
Re: My bt remote in our upstairs bedroom switches on the bt box and TV downstairs
I think you need to clarify exactly what is happening.
CMC01
Message 3 of 7
Basically my remote control in our upstairs bedroom also switches our downstairs TV and BT box. I have tried recoding the upstairs remote but to no avail, I have restarted both BT boxes but nothing changes, the remote still switches two TV's and two BT boxes. Any help would be appreciated. Thanks.
Les-Gibson
Recognised Expert
Message 4 of 7
Are you saying your remote controls a TV and Youview box from a different room with no direct line of sight between the two?
The Youview remote is infrared, not RF and so I don't see how that is possible unless you have a Magic Eye in the upstairs room linked to the downstairs room
                                                     If the Smart Hub 2 is BT's best hub yet then what does that say about its predecessors ?
CMC01
Message 5 of 7
Yes my remote upstairs switches my TV and BT box downstairs with no line of sight nor do I have a Magic Eye but still have an old sky box connected? Thanks again 😁
Les-Gibson
Recognised Expert
Message 6 of 7
Is the sky box downstairs and do you have a device in the upstairs room to allow you to control it from there?
If so, that is the cause of your problem. They're not selective, they simply relay any infrared signal they detect
CMC01
Message 7 of 7
Thanks a lot and seems to have solved the problem.
