Message 1 of 2
My youview remote is not working
My youview remote is not working. I've changed the batteries, reset and the blue light doesn't not work when the buttons are pressed. Can a replacement be sent or ordered?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: My youview remote is not working
Hi @Catherinadaniels1980 sorry about that I'm sure its a rite pain not having use of the remote. The easiest way to request a replacement would be to to have a live chat with the TV team on this link. Post back and let me know how you get on.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
