eames
Message 1 of 8
MyView's not working
It only started tonight that the box won't let me use the MyView option. Other items and Guide are OK. Whenever I hit the MyView it freezes and that's it.. Nothing else.
I have turned the box off for a while many times (by main and standby) it made no difference - can anyone help please?
7 REPLIES 7
Automan
Message 2 of 8
Re: MyView's not working
Under settings, check it is seeing your network (broaband connection).
If it can't see the outside world that option is removed from the menu.
EDIT: Whoops, the option is on your menu so perhaps a corrupt hard drive recording?
Telecom89
Recognised Expert
Message 3 of 8
Take a look at: http://support.youview.com/articles/Self_Service_FAQ/The-YouView-menu-is-not-working-properly-137086...
I've seen a youview box that worked properly after the 'hold front button down for 8 seconds' solution. Have you tried that?
eames
Message 4 of 8
I don't have front button on the box?
They're on top of the box - will that make any difference?
Distinguished Guru
Distinguished Guru
Message 5 of 8
See
https://community.youview.com/youview/topics/top_tip_soft_reset_reboot_power_cycling_maintenance_mod...
Try the the first two options - soft reset & power recycle
eames
Message 6 of 8
Hi,
  Thanks for the link to reset.. Unfortunately I tried them all as instructed - it still wont let me see my recordings/scheduled recording - I'm guessing the HD is corrupted after all?
Distinguished Guru
Distinguished Guru
Message 7 of 8
Well the next logical step is to try the maintenance mode reset and finally the factory reset - as described in the earlier link.
eames
Message 8 of 8
I've done that as well - made no difference, so that's why I'm assuming its a HD failure. Looks like I'll have to ring BT up and see what they can do.
