Kurin360
Message 1 of 49
NOT UHD I'm afraid
I am currently watching the Community Shield on the new YV box. I have checked the display settings and it's only showing at 1080p and not 4k. I have also checked the sky box and it looks like BTHD has downgraded there normal HD to make UHD look better. I'll be cancelling and sending back the box.
Tags (1)
48 REPLIES 48
scointer
Recognised Expert
Message 2 of 49
Re: NOT UHD I'm afraid
You need to check you are in the right hdmi input to get 4k, it is working fine and looks superb. If you use the wrong input (without hdcp2.2) it downscales to 1080p.
BT TV Expert
BT TV Expert
Message 3 of 49
Have you tried different HDMI ports on the TV?
It's definately running in awesome UHD!
BT TV expertSteveM
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
Randomprecision
Message 4 of 49
PQ was stunning I have to say, sharp as anything, I'm well pleased.
magpie03
Expert
Message 5 of 49
What's the best distance to sit from tv to get full benefit of ultra hd, I'm thinking of getting it but I sit very close to tv usually!
Randomprecision
Message 6 of 49
I'm sat about 10ft away watching on a 55HU7500.
Kurin360
Message 7 of 49
Hi, I'm running it through an amp (which is a 4k amp) I know the amp works as I run my MacBook Pro through it and I get 4k from that.
Telecom89
Recognised Expert
Message 8 of 49
You do have a 4K TV, yes?
Also just to confirm that your 'HDMI Display Setting' is actually set to 'UHD 50fps..'?
BT TV Expert
BT TV Expert
Message 9 of 49
Your amp may support the resolution but not the content protection needed (HDCP 2.2)
Steve
BT TV expertSteveM
Kudos”Kudos”
Kurin360
Message 10 of 49
Hi yes it's a Sony 4k TV. The settings are set correctly on the BT YV also (as you have stated). Should I try and run the HDMi direct (bypass the amp)?
