spencerb_2504
Message 1 of 1
NOW TV Recordings and Multi-Room TV
Hello all,
Just a few questions about BT TV:
1. Is it possible to record NOW TV channels to the normal recordings section on the BT Box. For example, can I record a tv programme on Sky One by pressing the record button in the EPG and it will show in the my recordings section.
2. With Multi-Room TV, I believe that the multi-room subscription comes with a non-recordable box? Therefore is it possible to take out the subscription and then buy a separate recordable box and will I be able to record programmes on that box from both Freeview AND my NOW TV and subscription channels.
Thanks all 😄
