hunter_mike
Message 1 of 2
NOW TV on BT
If I move to the new flexible tv with Now TV Entertainment and my Now TV account is billed through BT will I be able to use a Now TV Month Sports Pass at a later date that my son has received as a gift but doesn't want to activate until the Premier League starts again? The same would be the case for any future passes he receives as a gift. The Now TV website says that as a BT customer I wouldn't be able to add it on to my account on their website.
1 REPLY 1
NigelB72
Guru
Message 2 of 2
Re: NOW TV on BT
You can add the pass but will only be able to watch the channels through the app and not the EPG. So if you switch to the NowTV pack, don't add sky Sports until you've used your pass. You'll need to activate the pass through the NowTV app and then cancel it to avoid it automatically rebilling. Once you've used your pass, you can then upgrade your NowTV via BT to include the sports if you want and it'll be billed via BT in the future
