Woods190580
Message 1 of 3
NOW Tv
I’ve already got a now tv subscription as it is cheaper than paying what BT want to charge everybody, I also like the ability to flick through all the channels in one place. Is there anyway I can use my now tv account on the bt tv box, the channels are already listed but it’s says you have to subscribe via BT
2 REPLIES 2
StewM
Guru
Message 2 of 3
Re: NOW Tv
If you want to use the BT TV EPG you need a BT subscription. Otherwise you need to use the Now TV EPG.
Stew
gomezz
Recognised Expert
Message 3 of 3
Re: NOW Tv
Go directly into the NowTV app and navigate to a programme your existing subscription lets you watch. When you press OK to watch it then it will ask you to log in which you do using your usual NowTV login details. This is a one time action and you can now watch any programme your subscription covers. But you can't record and you can't select a programme to play from the Youview EPG. Having the channels listed on the Youview EPG is useful though for checking whats on when.
