Les-Gibson
Recognised Expert
Message 1 of 3
Netflix App on Youview box crashing
The Netflix app on my 4K box continuously crashes on launch, the only way to get it working again seems to be to turn the box Off / On, it then works fine until I launch the Prime video app after which the Netflix app goes back to crashing on launch, I guess that begs the question which of the two is causing the problem. I've tried a factory reset but it still prevails.
Anyone else had the same problem, is there a known problem with these two apps or have I got a faulty box?
♪♪I don't work for BT, I offer my time and help for free. If you'd like to leave a kudo, you may do so by clicking the rating button below.♪♪ 😄
2 REPLIES 2
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Netflix App on Youview box crashing
Les-Gibson
Recognised Expert
Message 3 of 3
Many thanks @zulu17 , I don't know how I managed to miss such a recent thread but c'est la vie
