Peter1812
Newbie
Message 1 of 2
Netflix sign up
Hi All
how do I stop my teenage kid from signing up to free Netflix through the BT infinity box?
or Can I delete it from the apps guide.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Netflix sign up
Hi @Peter1812 Sorry that the youngster has been able to activate the Netflix service from the BTTV box.
Have you enabled Parental Controls on the Youview box? I know that if you have then  you'll be prompted to enter your parental control PIN every time you enter the Netflix player on your set top box. I'm not sure if this will stop them activating the service but it may work.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
