Message 11 of 12
Re: New B.T Box
You would be better with a variable attenuator, as its more flexible.
Variable AttenuatorVariable Attenuator
You could turn the strongest signal down to 99%.
The digital decoder in the box, works best within a limited range, to deliver a very low error rate to ensure that recordings are not prematurely terminated due to high errors.
Normal TV receivers are not so critical, as errors are "hidden" within the picture, and only show up if the error rate is high, causing picture breakup.
Message 12 of 12
Re: New B.T Box
Okay thank you
