Anonymous
Not applicable
Message 11 of 14
Re: New BT 4K UHD box slow response
@Carlushawrote:
@Mazzawrote:
Its brand new.
The fact that the box is brand new does not mean it was assembled and commissioned yesterday. The actual software installed may be 6 months old or even older.
It may not even be a new box, they are refurbished to a standard which includes new case parts, this makes it very difficult to distinguish between new and recycled boxes
Mazza
Message 12 of 14
Well 4KTVFan, it seems as though it is my Panasonic Plasma somehow causing interference as it works ok with an LCD tv. My Sky box worked fine and I’ve never had any trouble with any other IR remotes in the vicinity of the tv so to me it is a problem with the BT box, I’d have thought that they would have tested them with Plasma TVs! Got a 2 year contract with this rubbish box :o(
The Mrs won’t be happy when she gets home.
Mazza
Message 13 of 14
Another 5 minutes on Google and I’ve fixed it, a bit of masking tape over the IR receiver on the BT box cuts out the interference but not the remote signal.
Tags (4)
4KTVFan
Message 14 of 14
@Mazza
Glad it's working for you now.
