jam2000
Expert
Message 1 of 7
New BTTV Box?
Are there any plans for a new BTTV box?
I would like to see one with the ability to record 4 or even 6 channels at the same time.
Also the TV box that EE use seems to have the ability to record 4 channels at the same time.
Since BT brought out EE mobile could they not work with EE to use their box and software to produce their own to use with BT TV?
Niko1
Message 2 of 7
Re: New BTTV Box?
I would go for the EE box if it had 4od and itv player and Netflix. Looks like a good box other than that..
Guru
Message 3 of 7
Re: New BTTV Box?
Perhaps you need to ask BT, not their forum 😏
Stew
srpsrp
Expert
Message 4 of 7
Re: New BTTV Box?
I always assumed recording 6 channels at a time was a bit of a gimmick, when would you really need to do that ?
There is not much wrong with the box itself IMHO, although a many, myself included would argue that the SW could do with improving.
jam2000
Expert
Message 5 of 7
Re: New BTTV Box?
Quite often now during prime time viewing I find the ability to record just two shows isn't enough.
gomezz
Recognised Expert
Message 6 of 7
Re: New BTTV Box?
I current run three twin-tuner PVRs but could easily make do with just two as far as recording capacity goes. It is the unique features of each one which make it tricky to pick one to retire.
ShadyCreek
Message 7 of 7
Re: New BTTV Box?
You guys!
I struggle to find one programme worth watching or recording in the same time slot, never mind two or more.
