Duncan999
Newbie
Message 1 of 2
New Infinity User - everything fine but IPC6023 on BT TV
Have just installed Bt Infinity with YouView box - On Demand is great, Broadband is good even if a lot slower than promised at 5-5 Meg - but BT Sport just come sup with IPC6023
I see losts of references to this but no actual solution - and how do you wake BT up to get it looked at?
Tags (2)
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: New Infinity User - everything fine but IPC6023 on BT TV
Hi Duncan,
Welcome to the forum, I'm sorry to see you're having problems with your BT Sport.  Check out this link for help with the IPC6023 error code. Let me know if you need any further help with this.
Cheers
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
