Deejaybee
Message 1 of 3
New Infinity/YouView User - Picture break-up on non-HD Channels
Hi
Apologies if this has been covered before, but does anyone else experience picture break-up on non-HD channels. I've tried everything so far, but picture quality (not sound) remains poor.  HD (sport and other) channels are perfect.
Apart from this I am very pleased with the performance and particularly the YouView box.
2 REPLIES 2
Telecom89
Recognised Expert
Message 2 of 3
Re: New Infinity/YouView User - Picture break-up on non-HD Channels
@Deejaybee wrote:
Hi
If you are referring to BT Sport this comes over your infinity line. Are the poor quality channels standard freeview channels received via the aerial? I had a problem once where an aerial flylead (the coax connection from the aerial wall socket to the YouView box) that worked ok with a previous freeview box didn't work well with YouView. The YouView tuner seemed to be not as good as the standard tuner in my TV. I replaced the aerial flylead with a cheap new one from amazon that claimed to be shielded. I think it was about £5. That seemed to solve the problem. Before you do that maybe rescan for channels to see if that helps.
Here's the original posting about this:
https://community.bt.com/t5/YouView-Boxes/Fixing-YouView-missing-poor-quality-freeview-channels/m-p/...
Deejaybee
Message 3 of 3
Hi
Thanks for the useful reply and link.  Yes, it's just the Freeview channels and I've tried rescanning the channels.  The new co-ax lead seems a good idea though.
Thanks again
