Message 1 of 12
New Interface?
I heard a rumour that BT are releasing a new interface/menu system for YouView later in the year.
Will my G4 T2100 YouView Box work ok with this upgrade?
If not, will there be a way to still watch recordings on the box?
11 REPLIES 11
Expert
Message 2 of 12
Re: New Interface?
The new interface is due to be available on all YouView boxes,
including the BT ones.
Distinguished Guru
Message 3 of 12
Re: New Interface?
The new update is designed to be compatible with all YouView boxes, except possibly for Sony TVs with built-in YouView.  Recordings should not be deleted during the upgrade.
Expert
Message 4 of 12
Re: New Interface?
Hope the update will start rolling out by Easter time.
Darren
Expert
Message 5 of 12
Re: New Interface?
it has started arriving on retail boxes so there is only BT with no sign of it now.
Expert
Message 6 of 12
Re: New Interface?
.... and long may it stay that way ....
[after reading the reviews about the Talk-Talk box rollout, I'd rather opt out till its 'been in the Wild' for a year or so]
... "If it aint broke ...." etc
Recognised Expert
Message 7 of 12
Re: New Interface?
Except it is broke, but what from what I understand this does nowt to fix any of the problems that have been there since Day 1.
(my current biggest beef is skip on active internet channel recording can be a bit of a mystery tour:  Where will it end up?)
Recognised Expert
Message 8 of 12
Re: New Interface?
BT boxes still in trial I guess, they want it right so taking their time to test.
Message 9 of 12
Re: New Interface?
This topic has been solved and is now drifting off topic.
If you want to discuss more, please make your own topic for it.
Thank you.
Expert
Message 10 of 12
Re: New Interface?
Thats the nature of a Discussion Forum - and its not as if the topic has degenerated, the new posts are simply expanding on the theme.
Thank you.
