brianflack
Message 1 of 6
New View Remote will not control TV
Despite following the simple instructions in the documentation, the new YouView remote will not control my Panasonic TV despite the Panasomic code being used. Is there a solution?
5 REPLIES 5
rarmitage124
Recognised Expert
Message 2 of 6
Re: New View Remote will not control TV
Have a look here: https://community.youview.com/youview/topics/controlling_panasonic_tv_with_bt_youview_remote
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
Distinguished Guru
Distinguished Guru
Message 3 of 6
If you specify what Panasonic model you have then it is possible others with a similar model can provide advice.
Also I believe Panasonic did follow many other brands and effectively supply compedtatively priced Tvs produced by Vestel (if it has a Made in Turkey on the label it could be one) so the Vestel codes might work.
brianflack
Message 4 of 6
Thank you. It is a Panasonic Viera Model number TX-L42E5B.
The YouView remote now works!! I used the step 6 referred to in that earlier link above.
Problem! The remote now controls the TV but I cannot change from the normal HDM1 I use for the TV to AV1 which I use for the DVD player. The YouView remote does not let me move off HDM1. Any ideas please?
skappy70
Recognised Expert
Message 5 of 6
What happens when you press the TV/AV button a few times, it should scroll through the ports?
brianflack
Message 6 of 6
Thank you, it now works OK. I have opened a new thread for another different query relating to the YouView box. Thanks to all of you for helping me out with my problems.
