notoriousdbp
Recognised Expert
Message 51 of 195
Re: New software release
Hi Steve, I've done 2 Maintenance mode recoveries this week and still have the issue with the box failing to record once it's gone to sleep in High Eco mode
---Remember to mark as 'solved' and give stars when you like a post---
mikegledholt
Message 52 of 195
Hi Steve  I've  been doing some recording tests in High eco mode on 15.14.0  and everything seems to be fine. I think my failed recordings that I reported earlier must have been for another reason.
notoriousdbp
Recognised Expert
Message 53 of 195
Thought I'd fixed it by switiching RF Loop on, but alas this afternoons "Tipping Point" didn't record. Now on Low Eco mode and will see what happens next update.
tullyhubbert
Message 54 of 195
Likeways, I run a test today from high eco mode. I set it to record from stations 507, 508, 513 & 101 and all recorded successfully.
mikegledholt
Message 55 of 195
I'm not sure this is the right place for this latest problem but here goes. I keep getting the YVM607 error message. I am on 15.14.0 with a direct ethernet connection, fibre 37mb. This happens when I want to watch an HD channel but then locks up the whole box so I can't get standard channels, just a black screen or menus. It eventually sorts itself out and I can then watch the standard but not the HD. After a while all is well again. This isn't a permanent thing, it may happen once or twice a night.  Also, I often get a loss of sound on video playback or pause/play. Has anyone else had similar problems and if so how did you sort it? I've rebooted, rescanned, and rebooted the hub!
mikegledholt
Message 56 of 195
I should have pointed out that I was getting this problem before the software update.
BT TV Expert
BT TV Expert
Message 57 of 195
Have you seen this?
http://support.youview.com/articles/Self_Service_FAQ/Resolution-for-YVM607-1370864321905/?l=en_US&c=...
Steve
Community ModeratorSteveM
Show your appreciation!
Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
scointer
Recognised Expert
Message 58 of 195
Just to try my luck and drag this thread back to the start 🙂
Steve is there any update on the new software release that will include the accessibilty updates or do we still have problems (hoping when it comes it will be more than the 17.3 update that has been around a month or more already - possibly even with some FR10 new goodies 🙂 :)). cheers.
mikegledholt
Message 59 of 195
Hi Steve. Yes I have tried all of that. I have an engineer coming on Tuesday & sods law - it hasn't done it for two days! I'll see how it goes & get back.
BT TV Expert
BT TV Expert
Message 60 of 195
The later, I think it will go straight to 19.x which is currently being tested by BT
Steve
Kudos”
