Chadwick45
Message 91 of 195
Re: New software release
The older one BT branded dtr-t1000
speedtrip
Expert
Message 92 of 195
Mine also upgraded to 18.3.0 after a manual check when it first came out of s/by - thought it would have checked itself, not needed a push?
However my ISP level is still at 90
BT TV Expert
BT TV Expert
Message 93 of 195
If you hadn't read this thread then it would have checked itself and upgraded over night 😄
BT TV expertSteveM
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
Message 94 of 195
Original Humax box here, still no update. Have checked manually.
scointer
Recognised Expert
Message 95 of 195
No update for my g4 box. I presume the g4 boxes will get this update as well seeing as we are stuck on a version that was deemed to buggy to release on the h3 boxes. Also what has happened to the 19 version that has been in test for the last month.
speedtrip
Expert
Message 96 of 195
If you hadn't read this thread then it would have checked itself and upgraded over night :smileyvery-happy:
Ha!
Wrong - it was circa 18.00 LAST night I checked - noticed this before that it doesnt check during the  l o n g  process of coming out of s/by, so assume it's only 'automatic' overnight ?
Also I thought Humax / BT boxes were going straight to 19 level
stevemarsbar
Message 97 of 195
Yep the boxes don't check for an upgrade on boot, only once per day during a configured upgrade window (currently overnight)
The rollout is limited to a set number of boxes each day
Message 98 of 195
Maybe BT should invest in a better server system so they can handle more than two downloads a day. That old HP ProLiant box must be getting on a bit....
mikegledholt
Message 99 of 195
I have the H3 and am still on 15.14 but have noticed the the boot up time in High Eco is now only about 30 seconds. Has anyone else had this change? At first I thought it was because there was a recording active but that isn't the case. Curious!!!
speedtrip
Expert
Message 100 of 195
Yes, last w/end my DTRT1000 Humax started coming straight out of s/by - I checked Settings, and altho it was still showing 'HIGH', I set it to 'LOW' and then back to 'HIGH' .... since then it has resumed its languid approach .....
