KennyRoss
Message 1 of 8
New to BT TV -unable to access non-Freeview HD channels
Dear all,
I stumbled across this form as I'm a new subscriber to BT TV (10 days ago)....in fact, as I own a listed house I have the whole caboodle, VIP BT TV, broadband, phone.
It was installed by Openreach, and the engineer was a disgrace. Came in, said he had to leave in 10  mins for the doctor, set up broadband, explained nothing and ran out the door. I'm making a complaint to BT directly about this.
Anyway, ever since it's been installed I have real problems trying to watch any HD channels which are non-Freeview. they work for 20 seconds, then freeze. I believe it's the common IPC6023 message.
Today, I can't get any non-Freeview channels at all, and have a IPC6011 message.
It's very frustrating, since this is costing over £100 per month.
I've tested the broadband speed, and there's no problems there. Done a few re-boots, nothing.
I realise that there are million questions out there where people have the same issues. Is this something where a phone call to BT will be any use ? Or is it my responsibility to go through all kinds of checks to try and get things working ?
Many thanks for any advice.
7 REPLIES 7
Anonymous
Not applicable
Message 2 of 8
Re: New to BT TV -unable to access non-Freeview HD channels
What hub are you using and how is it connected to your Youview box
KennyRoss
Message 3 of 8
Hi V,
It's a smart hub 2 and the YouView box is connected via a mini connector. The box can't connect directly to the ethernet cable, it's just too far away.
I've went through the trick of re-booting both the hub and the box, and then it actually worked. 2 hours later and I've lost all subscription channels again.
I'm going to call the helpdesk tomorrow to see what they say.
jilly3
Message 4 of 8
You should definitely call and get someone out to fix it if its only 10 days, you can cancel everything within the first 14 days, so i am sure they will help you out.
No point spending weeks trying to fix an installation problem on a forum, let them sort it out.
Anonymous
Not applicable
Message 5 of 8
I reckon there's a better than evens chance that the mini connectors are the cause of the problem. I suggest you find some way of temporarily moving the hub and TV box closer together so you can see what it's like when using an Ethernet cable
KennyRoss
Message 6 of 8
OK cheers. I'll try.
If they are the problem, is there a solution ?
Anonymous
Not applicable
Message 7 of 8
I believe BT will replace them but you'll have to confirm that with them
KennyRoss
Message 8 of 8
Thanks V for taking the time to reply.
