Stevek1311
Expert
Message 441 of 618
Re: Next generation YouView feedback discussion
@Jim-ladwrote:
They have got more on their minds at present with all the failed recording issues people (myself included) are reporting both on this forum and the Youview forum.
It's got so bad I darn't set it to record anything that we can't get on catchup.   I thinking of renaming it 'Can't View'.
Actually I haven't seen that issue, maybe it's box firmware build dependent.  But the live pause issue (which also seems to be box build dependent) persists
With the World Cup starting in hours they'd better not have any failed recording issues.  That's the very sort of free to air programming that YouView should be the bees knees for
Jim-lad
Expert
Message 442 of 618
Blimey Steve, you must be one of the few.  Big thread on this forum about the failed recordings and the Youview forum too.  I'm on the very latest firmware using DTR2100 - it's a case of set it to record and keep your fingers crossed.
BT and Youview has actually acknowledged the issue in a response on the 'failed recordings thread'.
Keyinferno
Message 443 of 618
Well they aren't going to ignore it, are they? But I've also have had no failed recordings, so its more than likely the problem is difficult to pin down.
Jim-lad
Expert
Message 444 of 618
I know what it is i.e. the EPG is failing to update/synchronise correctly.  The conundrum is why is it happening.
srpsrp
Expert
Message 445 of 618
I know what you mean, I ended up with nine episodes of 'Science of stupid' last week.
a) I've seen all the old episodes ( can't gaurentee that it only records the new ones)
b) if the disk fills up then apparently old recordings get deleted ( and  I'm not sure which ones it deletes exactly) This was one of the reasons I preffered the alphbetical list view so you can find things and check they are still there .
gomezz
Recognised Expert
Message 446 of 618
The why is easy:  It is uncoordinated timing between events happening at the server and locally on the recorder.  How to fix it may be more tricky.
Niko1
Message 447 of 618
Not a single missed recording for me neither.
scointer
Recognised Expert
Message 448 of 618
Sarah has just posted on the youview forum that humax have identified and have a fix in progress which is about to go into testing so fingers crossed.
‘Hi all,
Thanks for bearing with us on the issue, the issue has been identified and Humax are currently working on a fix which is due to be tested shortly.
We appreciate this is frustrating and assure you it’s being worked on as a priority. As soon as I have an update I will post on this thread.
Sarah‘
https://community.youview.com/youview/discussion/comment/18994938#Comment_18994938
Jim-lad
Expert
Message 449 of 618
Well it must be affecting a lot of users/is affecting a lot of users otherwise Youview BT and Humax wouldn't be pulling out the stops to get a fix in place.
If you haven't been affected then I would count yourself as being very lucky.
TimCurtis
Recognised Expert
Message 450 of 618
What I don't understand is why this has suddenly started happening & happens on previous software versions, not just the latest which was released at about the time this started happening.
