csyrimis
Message 1 of 3
No BT option
Hi
I received my new box today, a few issues setting up, eg not finding internet connection etc but mostly sorted.
Looking at the "Welcome to BT Vision" booklt that came with the box, there should be a "BT" option between the "On Demand" button and the "Settings" button in the YouView main menu.
I don't have it.  Any ideas?
2 REPLIES 2
drhowells
Recognised Expert
Message 2 of 3
Re: No BT option
Hi, sounds like your BT account hasn't been activated yet. Is the activation date today? You may need to give them a ring to check it has been turned on for you.
csyrimis
Message 3 of 3
Re: No BT option
This problem eventually sorted itself, the option is now showing.
Thanks for your reply.
