thebaconface
Message 1 of 7
No Crowd Noise on Sky Sports Main Event
Hi there!
For the past two weeks there has been no crowd noise on the Sky Sports Main event channel through NOW TV on my BT TV box. Sky Sports Main Event is the channel that usually has the crowd noise on and if I watch it through the NOW TV app, the noise is there. My friends and relatives who have Sky and Virgin are not experiencing this issue with this channel.
The BT Sport channels are working fine with crowd noise on the usual channels.
Any ideas what's going on here?
Thanks,
BF
6 REPLIES 6
NigelB72
Guru
Message 2 of 7
Re: No Crowd Noise on Sky Sports Main Event
I've just checked and there is definitely crowd noise on Main Event. Sky Sports Premier League is stadium sound only
thebaconface
Message 3 of 7
I do not have crowd noise on Sky Sports Main Event.
I am aware that Premier League is the one without, which is why I never watch that channel.
NeilO
Moderator
Moderator
Message 4 of 7
Hi @thebaconface welcome to the community and thanks for posting, I'm not sure if this is applicable but it would be worth checking if you have the auido description feature switched on. If it is on try turning it off to see if the crowd noise returns.
Press the AD button on your remote control, or press the main menu button then go to Settings > Accessibility & Language > Audio Description. ... Choose your preferred setting and go to Done.
Neil
thebaconface
Message 5 of 7
OH MY GOD THIS FIXED IT!!
Thank you so much!
I must've sat on my remote and switched that on at some point...  😂
Honestly, that had been doing my head in for like 2 weeks!
Legend.  🙏
NeilO
Moderator
Moderator
Message 6 of 7
Hi, @thebaconface no problem at all, I'm really glad that worked. 👍
Cheers
Neil
cooperman
Message 7 of 7
If only that would work for the commentators on the rugby, listening to the ref is much more interesting.
