Newbie
Message 1 of 11
No HDMI Signal - DTRT1000 - Cant get to Factory Reset
Hi,
I keep getting the No HDMI message from my TV when I turn my Box on
I have tried to get into Maintenance mode - but it wont even display the boot screen!
Software was last updated on 11th Jan 26.40.0
Any suggestions?
Jon
10 REPLIES 10
Distinguished Guru
Distinguished Guru
Message 2 of 11
Re: No HDMI Signal - DTRT1000 - Cant get to Factory Reset
Do you have a Scart cable you can try to connect  Youview box to Tv to determine whether it is a display or box problem ?
Also if you have alternative HDMI cable try that,
also if you have alternative HDMI slot on Tv try that.
Recognised Expert
Message 3 of 11
@Jon-99 wrote:
Hi,
Any suggestions?
Jon
You could try a different hdmi lead or hdmi port on your TV.
Or just unplug existing lead and plug it in again to see if that helps.
Failing that if you have a SCART lead and your TV has a SCART input you could connect temporarily via that instead (disconnect hdmi connection) and then set resolution to 720p and then disconnect SCART and try HDMI connection again.
See also: https://community.bt.com/t5/YouView-Boxes/Youview-HDMI-fault/m-p/1584583#M26203
Newbie
Message 4 of 11
Hi,
I have tried a different HDMI cable - no different
I have tried the other HDMI slot - no different
Scart works - so not a display problem
Any other suggestions?
Jon
Distinguished Guru
Distinguished Guru
Message 5 of 11
Well as you can get display with the Scart.
you can try
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode
the maintenance mode options 2 or 4 should preserve recordings.
If you still have a BT TV package then notifying them of the problem would be sensible as potentially a box replacement may be needed if the problem doesn't go away.
Suffice to say watching any key recordings is a good idea as you may lose them if a full factory reset or box replacement is needed.
Newbie
Message 6 of 11
I went through Maintenance reset via the Scart - then changed it back to HDMI - still no change!
Distinguished Guru
Distinguished Guru
Message 7 of 11
Well unless there has been any recent firmware upgrade to your TV I suspect the box may need replacement.
If you have a second Tv in the house to confirm that the problem exists when you connect the Youview box to that as well.
Newbie
Message 8 of 11
Its not a smart TV, so Im pretty sure there hasnt been any upgrade
Just on the phone to customer service - wish me luck!
Recognised Expert
Message 9 of 11
What video mode is the Youview box set to? What video mode is the TV set to?
Newbie
Message 10 of 11
How do I check that?
