Message 1 of 3
No UHD 50fps 10bit option on BT Box Pro
Has anybody had this issue?
I don't get an option to switch to UHD 50fps 10bit on my BT Box pro.
Only options I have are:
720p
1080i
1080p
UHD 50fps 8bit
Using an HDMI 2.1 cable on a compatible TV where HDR works with every other device using the exact same HDMI cable.
I have rebooted/power cycled the box.
Tags (4)
2 REPLIES 2
Message 2 of 3
Re: No UHD 50fps 10bit option on BT Box Pro
Solved.
Deep Colour was not enabled for this devices input on the tv under general/devices/hdmi settings.
Message 3 of 3
Thanks for letting us know how you get this sorted @samplethief .
We appreciate you taking time to do that. Kudos to you 😉
Cheers
David
