GraemeF
Message 1 of 3
No channel dialogue box
Terrestial aerial died on me .. no problem. Get channels by Sat. How can I remove the no channel dialog box (it is annoying) and does anyone know if I would still be able to get the new internet channels. I no longer seem able to getinto the guide. Otherwise I just plan to use box for on demand.
2 REPLIES 2
MartinH
Expert
Message 2 of 3
Re: No channel dialogue box
The EPG data comes from the aerial, no aerial no EPG, no channels (beyond the internet ones) and no recording.
Distinguished Guru
Message 3 of 3
If you have no guide then I'm not even sure you could access the internet channels as this is done via the guide.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
