hellothere19
Message 1 of 14
No signal on bt tv
My internet is working fine. I can access apps and Netflix etc  WiFi is working fine too
however when I go to bt tv, I get the message no signal. I restarted the Youview box, the signal turns blue but still no tv. I don’t see the usual startup images from Youview either
any ideas what I can do or is the box faulty?
thanks
13 REPLIES 13
Keith_Beddoe
Message 2 of 14
Re: No signal on bt tv
@hellothere19
Check the HDMI cable from the YouView box to your TV, as it may have come loose.
hellothere19
Message 3 of 14
Hi Keith
I tried that but to no avail, it’s plugged in fine
Keith_Beddoe
Message 4 of 14
It possibly faulty, but lets see if any of the other forum members can suggest anything, perhaps one of the maintenance modes?
Have you tried a different HDMI socket on the TV?
hellothere19
Message 5 of 14
Didn’t work either
let’s see what others will suggest.
Keith_Beddoe
Message 6 of 14
zulu17
Distinguished Guru
Distinguished Guru
Message 7 of 14
Not sure which Youview box model  you have . If it is one with a Scart connection and you have a Scart cable and connection on your TV I would suggest you  disconnect the HDMI and see if a SCart connection works.
hellothere19
Message 8 of 14
Yes. Doesn’t work for me
hellothere19
Message 9 of 14
I don’t have a scart cable at home
as the internet is working fine, I’m pretty sure it must be the box
hellothere19
Message 10 of 14
Well, BG tv is back on strange indeed .... let’s hope it’s back for good
I’m out of contract anyway so need to look into or upgrading my current BT subscription or moving somewhere  else.
Thanks all for looking at my post on  a Sunday 🙂
