Les4048
Message 1 of 4
No signal
Recently moved house and fitted my YouView box but it states no signal from aerial. I’ve checked in settings and signal strength and quality are both zero. I can’t understand why it won’t work as the television works with the aerial through the box but not when I choose the source for the box. If box doesn’t receive a signal how can the television work through the box when the box is switched off ?
thanks in advance
3 REPLIES 3
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: No signal
Have you retuned your Youview Box since moving house ?
Les4048
Message 3 of 4
Re: No signal
No I haven’t. I thought if there’s no signal it wouldn’t retune. I only moved half a mile away so in the same signal area
Les4048
Message 4 of 4
Re: No signal
Retuned box and it’s now working, thanks
