wpc1
Message 1 of 2
Now TV
Hi , regarding Now TV on BT , can you record and pause as you can with other channels or does it just work as it does in the App
1 REPLY 1
Anonymous
Not applicable
Message 2 of 2
Re: Now TV
If it's part of your BT subscription then it will appear in the EPG and you can record it
