Rjf87
Message 1 of 3
Now tv vouchers
I have bought a now TV stick which comes with a code for a couple of months entertainment pack.
I've already got now TV within the bt tv package, I was wondering whether I can apply the code to my account for the free months, or will it not work as I pay bt rather than now?
2 REPLIES 2
-Richie-
Guru
Message 2 of 3
Re: Now tv vouchers
They won't work, the NowTV vouchers are redeemable via NowTV only.
If you have Big Sport for example, you can watch all sport content notmally, create a 2nd account for NowTV and watch the Entertainment passes via the app, only the BT subscribed content will show in the EPG and be recordable, external passes work via the app, hope that helps.
Rjf87
Message 3 of 3
Re: Now tv vouchers
Thanks for your help, that what I suspected.
