DarrenW
BT TV Expert
Message 11 of 111
Re: NowTV Channels in EPG Unavailable
An issue on our side unfortunately, we will put something in place to hopefully stop it happening to other customers
Andypandymonium53
Message 12 of 111
I'm curious too as I have exactly the same issue.
DarrenW
BT TV Expert
Message 13 of 111
Hi @Andypandymonium53
Are you still getting problems? I can see the Youview box was registered this evening, did you log in to nowtv.com and manage your devices?
Andypandymonium53
Message 14 of 111
Yep, registered and working. Thanks. After you had fixed the caller’s I did a factory reset. Then I went through the NOW channel cycle described by the caller. This time though at the end of the cycle I got the instruction that I had too many registered devices in addition to my unworking YouView one, and was prompted to go to my NOW account ‘devices’. I unchecked one of the options (even though it seemed I wasn’t quite at the six limit) and hey presto my NOW sports channels appeared on my BT EPG. A bit of bumb luck and some behind the scenes magic I think!
Donnarobbo112
Message 15 of 111
I am having this same problem !!
need it sorting
DarrenW
BT TV Expert
Message 16 of 111
@Donnarobbo112  I can help you if you message me some account details via private message
Donnarobbo112
Message 17 of 111
Done
DarrenW
BT TV Expert
Message 18 of 111
Thanks @Donnarobbo112
You're issue is now fixed, if you manually check for a software update, new software should be located and installed. Your box will restart, post that, you should see your channels in the guide.
Software Update Steps:
1. Press the Home button on the remote
2. Scroll along to Settings, press OK
3. Scroll down to Software Information, press OK
4. Press OK on Update Software
Donnarobbo112
Message 19 of 111
Great all sorted thanks
YorkshireLakeside
Message 20 of 111
I have a similar problem, Software updates didn’t work but NowTV app Works fine.
what was the solution To get items on the EPG?
thanks
