DarrenW
BT TV Expert
Message 71 of 111
Re: NowTV Channels in EPG Unavailable
Morning @tonyblake72 , I'm sorry that you had to experience this problem 😞
It is fixed now, if you could check for an update please you should be able to access your service.
Software Update Steps:
1. Press the Home button on the remote
2. Scroll along to Settings, press OK
3. Scroll down to Software Information, press OK
4. Press OK on Update Software
tonyblake72
Message 72 of 111
Done update and worked a treat. Many thanks.
Rossm538
Message 73 of 111
@DarrenW also having the same issue with nowtv channels not on EPG. Set up box today so all updates are done
andyminns
Message 74 of 111
Hi @DarrenW
Sorry to add to your workload, but I have just set up my new BT TV package today and have the same problem. AMC, BT Sport and 399 are showing, but no NOW TV channels on the guide? I have run the update to the latest software, reset the box and re-scanned channels? Can you help please?
I had to convince my wife to change over to BT from SKY, but not so sure this was a good move now!!
Andy
DarrenW
BT TV Expert
Message 75 of 111
@Rossm538
Sorry for the delay relying, you all sorted now?
DarrenW
BT TV Expert
Message 76 of 111
Hi, @andyminns
Sorry for the poor experience, it should be fixed now if you could check for a software update via the settings please.
andyminns
Message 77 of 111
Thanks for the quick response Darren - just updated and all the channels are here. You saved my bacon! 🙂
Andy
Eddy600
Message 78 of 111
Is it possible to look at mine as well I have updated software and done a factory reset but now TV does not show in the epg thank you!
DarrenW
BT TV Expert
Message 79 of 111
Hi @Eddy600
If you do a software update now it should be sorted.
Rossm538
Message 80 of 111
Yes all sorted thanks
