Message 1 of 2
Ordering the app list
Hi,
Is there a way to order or remove apps from the list?
When you press the blue home button, then scroll down one position you see a long list of apps.
Is there a way to re-order them to get your favourites to the start and to remove the ones that you don't use?
Phil
1 REPLY 1
Message 2 of 2
Re: Ordering the app list
You would think that with this new, improved, all singing, all dancing new home screen it would learn from your usage and adapt the order to push your most used apps to the front of the list. Of course it doesn't as I suspect it is more aimed at pandering to the wants of the service providers than to those of the users who pay their bills.  🙄
