sps1013
Message 11 of 15
Re: Overly confusing options for BT YouView
Chaps,
Have took the advice and purchased a set of 500Mbps PLA's.
I connected them as would be the case for a possible BT TV purchase and got the following results:
Infinity speed direct to hub: 74/16
PLA's: 62/12
I am assuming this speed will be sufficient to run the multicast channels. I can also view the test channel.
Assuming I add to my infinity package, the price seems to be £7 plus £3 for HD and the set up fee.
Might give it a try.
sps1013
Message 12 of 15
Any comments?
Distinguished Guru
Message 13 of 15
Sorry I meant to reply but my daughter arrived from England. Yes that will work perfectly well. Better speed than I have and all is well
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Deathtrap3000
Recognised Expert
Message 14 of 15
Its more about having a consistent throughput. Without that your streams would keep freezing. This is why bt dont provide them on new installs anymore.
sps1013
Message 15 of 15
Thanks folks, the pla speeds are pretty consistent so think all should be ok.
Will order and hopefully won't take too long for the equipment to arrive!
