AleT
Message 11 of 30
Re: Pairing iPhone
Did you pair them up recently? It's the actual pairing process which we can't get to work.
spec_d
Message 12 of 30
Re: Pairing iPhone
yes - today I deleted the obsolete Youview App and installed the BT App 3.3.9.
I then deleted the old pairing on the T4000 showing as "iphone 6" and then re-paired the devices without issue. This time the phone is listed as "mobile device" though. Sent a record request from the phone app and the recording was acknowledged after 5 minutes, which is a slower response than the old Youview app.
AleT
Message 13 of 30
Re: Pairing iPhone
App developer says some boxes are incorrectly reporting that they don't support the new recording service. They are investigating as a priority.
Blueastra0
Message 14 of 30
Re: Pairing iPhone
Having same issue.
Received a new 4000 Box and have gone through the pairing process several times plus the troubleshooting.
the error code is not listed anywhere AY182.
Software on Box  is up to date.
IOS app is latest too.
My iphone 7 worked well with previous old box and I could send recordings to the box.
Any help appreciated.
VeteranISPUser
Recognised Expert
Message 15 of 30
Re: Pairing iPhone
Hi @Blueastra0
I am hoping that a Mod has already picked this up as long as @JJ4 has replied to his PM. 🙂
https://community.bt.com/bt/board/message?board.id=YouView&message.id=55345#M55345
JJ4
Message 16 of 30
Re: Pairing iPhone
I did reply and am waiting for a response. I tried to pair with iPad and Android phone without success.
VeteranISPUser
Recognised Expert
Message 17 of 30
Re: Pairing iPhone
Thanks @JJ4
blouden
Message 18 of 30
Re: Pairing iPhone
Software just updated on tv box - tried pairing again - after all that is what the error message said needed to happen.
still can’t pair my phone.
AleT
Message 19 of 30
Re: Pairing iPhone
Mine now allows pairing.
Blueastra0
Message 20 of 30
Re: Pairing iPhone
Still have the same issue despite reloading the app etc.
