blouden
Message 1 of 30
Pairing iPhone
Trying to pair my iPhone using the BT app with my YouView box.
app says that I need to upgrade the software on the tv box, but settings say already running most up to software.
probably missing something really obvious.
help please.
29 REPLIES 29
AleT
Message 2 of 30
Re: Pairing iPhone
I have exactly the same error with a brand new install and an android phone.
zulu17
Distinguished Guru
Distinguished Guru
Message 3 of 30
Re: Pairing iPhone
Assuming that the BT TV Youview box  is either a T4000  or T2100 I doubt whether the issue is the software version on the box.
Might be worth trying to pair again with the phone after ensuring that  mobile connection is turned off on the phone so it has to connect by Wi-fi.
If that doesn’t work I suggest detailing the Phone model and iOS or Android version and BTTV box model.
blouden
Message 4 of 30
Re: Pairing iPhone
Hi
thanks for the reply - tried this and had no success.
The YouView box is a Human DTRT2100
I am using an iPhone 11running iOS 13.3.1
AleT
Message 5 of 30
Re: Pairing iPhone
I have a T4000 running the latest software and my phone is a Pixel 4xl running Android 10.
The TV box is connected to my Hub2 using BT mini connectors.
Turning off mobile data makes no difference.
Dode
Expert
Message 6 of 30
Re: Pairing iPhone
Using an iPhone Xr and I've just upgraded to iOS 13.4. Also a DTR2100. It wouldn't let me record using the app. a little while ago but it seems to be OK now. Only thing I've done is turn Location Services for the app. off and then on. May be worth a reboot after that.
spec_d
Message 7 of 30
Re: Pairing iPhone
This probably epxlains what has happened:
https://support.youview.com/mobile-app/
There was a new Youview IOS app about 2 months ago that caused problems for me. Record requests were ignored by my BT YV box depite unpairing and then re-pairing iphone to YV box attempts.
Today my YV IOS app is showing "temporarily unavailable" and a BT error code YVM5004
The app that should now be used for remote recording is:
https://www.bt.com/bt-tv-app
But I have not used it yet in anger
AleT
Message 8 of 30
Re: Pairing iPhone
Thanks for that info, however I am already using the BT app, not the YV app.
It is the BT app which cannot connect to the TV box.
blouden
Message 9 of 30
Re: Pairing iPhone
Tried all of the suggested. Upgraded iOS to 13.4, turned off location services and back on again , turned off mobile and used only Wi-fi.
I’ve rebooted the box and my phone.
Using the BT app not the YV one. it has no trouble finding the box - just won’t pair with it.
(AY182) is displayed. Doesn’t seem to be a recognised error code.
All really frustrating.
spec_d
Message 10 of 30
Re: Pairing iPhone
Apologies.
I have the BT app working (v 3.3.9) on an iphone running 13.4 iOS and is sending record requests OK.
The BT box is a T4000.
